1/24 1/24 Hasegawa Porsche 968
Medium
Anything Goes
Whatever is affordable
WIP
GraemeB
Well Guys , with the disaster that has struck with the Other Porsche , the 944 I have decided to start another while i wait for the Decals so no rush.
This is one that I bought out of a deceased estate, it is one of around 50 , these are all referred to as my Tupperware Porsche's as they have all been stored in plastic containers.
What you see in the Pics is all that there is,
All pieces of the Sprues
No Plans
Some parts have been assembled
Box image is off the Net
IMG-20240428-WA0036.jpgIMG-20240428-WA0037.jpgIMG-20240428-WA0038.jpgIMG-20240428-WA0039.jpgIMG-20240428-WA0040.jpg
Luckily there is a very small decal sheet , it is a much newer kit than the other 944 so i hope that all is ok this time round.
Will build it out of the box with some scratch as well.
Time to scribe the panel lines as i usually do , will follow with an update once done
Thanks for looking and as usual comments are always appreciated
Hi GraemeB, you have collected some beautiful kits, a friend of mine is a huge Porsche fan, also works in a Porsche garage, and that man had almost everything there was to collect from Porsche, but he stopped and got rid of everything and I have two shoe boxes full. Got Porsches
So I still have a lot to do
I wish you the best of luck with the restorations of those beautiful Porsches
Good luck
Thanks for the comments .
@ Marc, Yea i am a bit of a Porsche nut as well, probably a very loose nut :winking:.
Well so far , I am just on 5 hours of sanding and scribing and she is ready for the first coat of primer .
I might however give the fuel cap some more attention as it is sticking up proud of the body and should be flush with the body
Scriber jumped out of the lines in a few places but not that bad and the primer should sort these blimps out .
Also went through the box of parts and all are accounted for , so good to go there , however some parts have been glued together so this may just complicate the painting process. also managed to down load some plans off the interwebs.
WhatsApp Image 2024-05-07 at 19.55.24_9428c47c.jpgWhatsApp Image 2024-05-07 at 19.55.24_f826e6b4.jpg
Thanks for looking and cheers till next time
G
Hi Chaps . now that the wingy thing is out the way , back to the Porsche, Finished scribing her and hit it with some grey primer as is my process, well all looks good no issues detected. I will now flat her and then hit her with black primer before final paint. Must say i am quite satisfied,IMG-20241012-WA0177.jpgIMG-20241012-WA0178.jpgIMG-20241012-WA0179.jpgIMG-20241012-WA0180.jpg
Thanks for looking , i will ad some photos of engine progress a bit later on.
Well guys here as promised , put the Engine together , not to much hassle . just the plug wires got fiddly. but its donestuttcars-968-engine-copyright-porsche.jpg
Here is the pic of the real engine , mine close enough i think, will add additional detail as i assemble .
IMG-20241012-WA0189.jpgIMG-20241012-WA0190.jpgIMG-20241012-WA0191.jpgIMG-20241012-WA0192.jpgIMG-20241012-WA0193.jpg
Used blue for the plug leads just to add some more contrast
Thanks a lot for looking
Comments most welcome
