1/35 Tatra 805 (Tonda) [wip]
GraemeB
As requested by Erwin, here the posts for this build.
Model : Tatra 805
Manufacturer : Tonda
Scale : 1:35
Media : Vacuum Formed, Resin and Scratch
Reference : Internet
Well, firstly one could ask why a vacuum formed kit in today’s injection molded and resin world, it goes something like this, I received this kit from a friend a few years ago (Thanks Erwin) and there it has been laying until now, me being petrified by vacuum formed kits as a result of all the bad things that I have heard about them. Well on my recent little escapade to Belgium I found another Vacuum formed and resin kit, this one also a tuck, this time a tank transporter, well I couldn’t resist it and had to have it, what a dilemma, 2 of these horrible kits and me to afraid to build them.
So it was decided that I would use the Tatra as a practice run, for the Ursus A that is lying next on the pile. A bit of quick searching on the Internet, where I found very little on building Vacuum for and of I went.
Here is a pic of the Box Art. You will notice that the date of manufacture is 1992, so a relatively new kit by Today’s standard.
There are 3 A4 pages that are the plans, all in some language that I can’t read, but the pictures are good and I can read them well.
I never took pix of the formed parts as these are all white and crap to photograph, will just have to see what comes of this.
_________________________​
Well Gents, progress is being made on this beastie, the plastic is not t bad and seems to be fitting quite nicely. It just takes a lot of time sanding the mating surfaces to get them level and fitting properly, The smaller parts are really painful because you loose most if the skin on your fingers.
Here are pix of the engine, you will note that I have added some wiring to it, I will still add a few other wires and goodies just to beef it up more. It must be noted that this is an Air Cooled engine and that most of it is covered with a steel plate so there is not really room for much improvement.
Here are some pix of the chassis, All i will still add here brake pipes to the individual wheels and a few Wires for the lights.
This build is really starting to grow on me and it looks like it might make a very unique little build for the tables.
Dont get me wrong, Vacuformed is a huge amount of work, there is proberbly already 30+ hours in it.
Later
Hi GraemeB,dit is een ongekend merk van bouwdozen voor me,maar zoals je weet is er voor alles een begin he :)
Lijkt er een beetje op dat er wat details zijn die wat minder uitkomen maar dat kan de pret niet bederven.
Veel succes met deze kit;)
nice progress with this one. didn't know that there were vac-form kits of trucks and so on...
seems a lot of hard work, but then you also have something unique...
Hey G,
Welcome here m8.
Well done with youre vacu-model, It's nice to see so an special model. Go on m8. ;)
Vacuum gevormde modelbouw ? Eerlijk gezegd , ik wist zelfs niet dat dat bestond ! Nu ja een mens kan ook niet alles weten.....
Het is een model dat je praktisch nergens ziet en dan ook nog een vreemd uitziend chassis, dan kan dat niet anders of hij komt van bij Erwin !
Hieraan zou ik me nooit durven wagen, om gek van te worden volgens mij !
Thanks for the Kind comments
It is greatly appreciated, yes it is something else building vacuform, your fingers take strain with the sanding of the parts but there are no other easier options, it is very uncommon and this is the first that I am doing, I do however have 3 more that need building, one day.
G
Sta me toe een kleine toelichting te geven.... modelbouw (volledige modellen) in vacuform bestaat al sinds de jaren '50, vooral in het voormalige oostblok was het heel populair.
In 1960 bracht Mattel zelfs een klein vacuform apparaatje op de markt waarmee je allerlei kleine dingetjes kon maken, vandaag kennen we vacuform vooral van de zeilen bij plastic zeilschepen en ook Miniart gebruikt het nog voor haar gebouwen.
En dan komt er nu en dan nog eens zo'n uitzonderlijk model tevoorschijn zoals deze man hier nu bouwt.
This is indeed a very special model, just because it is vacu form :)
Never realy liked the material, I always have troubles to create a clean seem...
Still I am very interested in your adventure ;)
Nog nooit van gehoord.. Als ik het goed begrijp vormt men het 'plastic' door dit vacuum te trekken in een soort mal?
Veel succes met de bouw in ieder geval, je hebt een speciaal model gekozen om hier op het forum mee te beginnen. Je hebt er alvast veel belangstelling mee gekregen!
grtz
Idd Sheriff, de procedure is heel simpel en goedkoop... de machine lijkt op een gewone braadoven, men plaatst een mal onderaan de oven, daarboven een plaat plastic en brengt de oven op temperatuur om het plastic zacht te maken, dan trekt men de oven vacuum zodat de plastic over de mal heen wordt getrokken en klaar!
Maar ik vind het verschrikkelijk materiaal om mee te werken, dat is niet aan mij besteed.
Well Guys here is some more and thanks for the great comments, really appreciated
As for the Chassis I have added the subframe and some brake pipes, I still have to add the tow hitch and some bump stops.
I have also joined the Cab Front and the roof.
Added some detail to the back wall of the cab along with some sanding and filling
Fuel tank and tool box
Then I had some fun with the doors, wanted to give them some body so i added a little frame arround the door amd window.
Then covered it
Trimmed them to size and added a bit of detail to the inside of them . still have some work to do on them but this is how they look now.
Some Comparison pix of the 2 door where you can clearly see what I have done
Hope you all enjoy. Still have loads of work to do, and plenty of sanding.
Going nice :)
Giving some thickness is improving the door much more.
Hi Graeme,this is a nice improvement on your model.I like to do some changes my self to on models.Its going good so i can see here ;)
